anyone good with amps?????????????????????
  • pughy1988
16 years 8 months ago #126284 by pughy1988
ok ive found 1 of my OLD amps in the loft, its a 1000w sub zero amp. BUT the power protecion light comes on and it wont work?? any ideas wat i can do? can it be fixd
[img:3n2ifadi]http://offsite.warwickshiremodified.co.uk/signatures/pughy1988.jpg[/img:3n2ifadi]
16 years 8 months ago #126285 by Woody
Replied by Woody on topic anyone good with amps?????????????????????
Sounds like the earth, may need a larger/thicker earth wire.
16 years 8 months ago #126347 by Bluefox
Replied by Bluefox on topic anyone good with amps?????????????????????
Woody beat me to it.
Yeh, it'll more than likely be the earth wire. If after fitting a bigger/good earth it still won't turn on, double its usefulness as a handy paperweight...
16 years 8 months ago #126351 by Bluefox
Actually, I should probably move this to a more relevant section...
16 years 8 months ago #126384 by Chris CW
Replied by Chris CW on topic anyone good with amps?????????????????????
Again, sounds like the earth wire, but it could be the contact its making with your car thats the issue - is it clear from paint etc? And dirt? Next thing to check is the fuse, see if theres any change when you pull it in and out, if so, the contacts on that might be alittle messy too
  • pughy1988
16 years 8 months ago #126546 by pughy1988
Replied by pughy1988 on topic anyone good with amps?????????????????????
bigger earth wire.. hmm....maybe, mine is abit small
16 years 8 months ago #126551 by Woody
Test it with two or three wires if you dont have a thicker one spare
  • pughy1988
16 years 8 months ago #126553 by pughy1988
i gt thick wire :)
16 years 8 months ago #127079 by mongman
Replied by mongman on topic anyone good with amps?????????????????????
my centre spl1000 does the same. the other runs on the same guage earth cable and there's power. fuse is ok so it's been troubling me for months. hopefully your problems the same so we can both benefit.
16 years 8 months ago #127088 by Chris CW
Yeah Im guessing it will be the earth folks, it doesnt matter how thick your earth cable is if you havent got a good contact to the metal to ground it all
