Hesitation...
- Brookesy91
16 years 9 months ago #125564
by Brookesy91
Hesitation... was created by Brookesy91
Hi all,
After a long run today my Zed has started hesitating alot, ive checked the sparks plugs and they are fine, Recently had HGF so the majority of stuff has been replaced and filled up, so my mind has come to a blank.
It only does it when under load, mainly low revs...
any help would be appreciated
P.S its a 1.4 105, with 59k on it
Thanks
Thanks
- GhostWKD
16 years 9 months ago #125566
by GhostWKD
'91 R32 Skyline GTR <!-- s:) --><img src="{SMILIES_PATH}/icon_e_smile.gif" alt="
" title="Smile" /><!-- s:) -->
Replied by GhostWKD on topic Hesitation...
checked for vac leaks? other than that map sensor or lambda sensor plugs been checked?
- Brookesy91
16 years 9 months ago #125568
by Brookesy91
Replied by Brookesy91 on topic Hesitation...
I thought that if it had an issue with one of the sensors it would turn on the engine managment light?
no i havent checked for vaccum leaks, ill have a look!
thanks mate
thanks mate
- GhostWKD
16 years 9 months ago #125569
by GhostWKD
Should do but doesn't always, vac hose leak always a good place to start though
16 years 9 months ago #125572
Replied by Bee on topic Hesitation...
idle control? when does it do it? all through the rev range or just at certain revs?
- Brookesy91
16 years 9 months ago #125573
by Brookesy91
she is fine idling bee, its only low revs so from 1k to 3k and it only misses if its under load.
- Belmont Turbo
16 years 9 months ago #125591
by Belmont Turbo
Replied by Belmont Turbo on topic Hesitation...
check the HT leads are in good condition not cracked ect. if you look in the dark you might see them arking
- Brookesy91
16 years 8 months ago #125632
by Brookesy91
problem sorted!!
one of the rubber hoses that comes from the coil pack to the spark plugs had split and it was arching off the head, put some insulation tape round it and its running well now.
thanks for the help!
