Saxo Help!
  • GTnomez
15 years 6 months ago #162308 by GTnomez
Saxo Help! was created by GTnomez
Need some help guys on the Citreon Saxo 1.1i (dont think its injection as i can see the carb). Firstly the Saxo has been great, i have driven it through out the year with no problems bar one (thinks it runs a bit rich on startup) but thats never really hindered anything. Lent my brother the car for less than a day and he manages to blow the car.
He "says" that he was on the M-way driving about 60-70 and it just conked out and there was a puff of black emitting from under the bonnet! He got towed home and i had a looked at it the next day.
First thing i did was try start it, battery was dying and i guess that was from being towed home with the ACC on so the power steering was active. Charged it up and it just cranked over, it didnt even try to start at all, just was cranking (i know the difference in noise between just cranking and cranking while trying to start as ive just done the build on the starlet). So it was just cranking like there was no fuel or spark.
Pulled the plugs out, while in the leads and turned the car over, i could see the spark in the plugs so it was sparking. I could smell and see the fuel in the carb so that would suggest it was fueling but the problem is that it is not igniting :( I cleaned and dried out the spark plugs incase they were flooded with fuel from the constant turning over and still nothing.
What i did notice was when i popped the bonnet, there was oil splatter around the bay, i pulled all the plastics apart (what sits on top of the rocker cover and goes to the air filter and carb) and i saw the it was full of oil, especially the ducting that goes to the carb, and inside the carb (by the butterfly) there was oil all over it. Would that cause it not to start?
Dont really know Saxos so hoping some can shed some light please. Ive explained pretty much everything what happened so hope its clear.
Cheers!
15 years 6 months ago #162310 by mini danny
Replied by mini danny on topic Saxo Help!
if it doesnt sound like it wanna fires ild do a compression test and see if he fcuked the piston rings which would allow oil into the piston but dont know if it could reach the carb or not :/
  • GTnomez
15 years 6 months ago #162327 by GTnomez
Replied by GTnomez on topic Saxo Help!
It should still start even if the piston rings cracked, trust me i drove my car on 3 cylinders for like 6 months lol
15 years 6 months ago #162338 by mini danny
GTnomez wrote: It should still start even if the piston rings cracked, trust me i drove my car on 3 cylinders for like 6 months lol
true unless theyve all cracked :/
  • GTnomez
15 years 6 months ago #162357 by GTnomez
If a tooth slipped would this cause it? Because i think it may have.
I also know what happens to the engine if the timing is out LOL
15 years 6 months ago #162359 by pez
Replied by pez on topic Saxo Help!
lmao wtf noman.. put the engine to tdc and check everything is where it should be.
could also try cleaning the carb up
  • GTnomez
15 years 6 months ago #162364 by GTnomez
^ Tell me about it man.
Havent got a timing gun, will try skank one from Halfrauds though. Is there a notch somewhere on the saxo to indicate tdc? The starlet has it on the crank pulley but the saxo f*ck knows! Will have a go on changing the cambelt and aligning it and set the timing.
My other brother (who was in the car with him) said there was a LOAD of black smoke coming out the rear before it conked out :$
