bloomin missfire!
  • Turbo Ted
17 years 11 months ago #12037 by Turbo Ted
bloomin missfire! was created by Turbo Ted
alrite guys,was on my way home and my car has suddenly developed a missfire.seems to be getting gradually worse and is doing it at all engine speeds.
for anyone that doesnt know its a 2004 1.4 16v renault clio.
oh and it has not brought on an engine light,i believe it could be the coils as apparently they are common on renaults
17 years 11 months ago #12038 by retro dan
Replied by retro dan on topic bloomin missfire!
coil(s), lambda, leads?
  • Turbo Ted
17 years 11 months ago #12039 by Turbo Ted
Replied by Turbo Ted on topic bloomin missfire!
its coil on plug and there are no engine lights on so i dont think it would be lamda or coils apparently do bring on the engine light
17 years 11 months ago #12040 by Woody
Replied by Woody on topic bloomin missfire!
Most likely the Coils but could be leads, plugs, ignition pack, earth problem or even the cat. Is it poppin alot or just losin power?
Edit: On pre 01 Meganes it doesnt always bring up the engine light.
17 years 11 months ago #12041 by Andy
Replied by Andy on topic bloomin missfire!
not good with engines but good luck sorting it!
  • Turbo Ted
17 years 11 months ago #12045 by Turbo Ted
i only replaced the plugs about 2 months ago,and its coil on plug so theres no leads to go wrong.
the car pops and drags when it does it,it is gradually getting worse too,as originally it was only when i was accelerating hard but now it is at all engine speeds and loads.
does sound good when its happening though,i have made a renault impreza!
17 years 11 months ago #12051 by slacker
Replied by slacker on topic bloomin missfire!
moved by me :)
17 years 11 months ago #12052 by retro dan
sounds like plug/lead or something stupid, take one out see if it sparks, then the next etc? if you havent yet..
You got a de-cat, or standard? may be blocked cat, but never usually causes missfire much, usually just blows the shit out.
just check the simple stuff, if you know someone with a clio, try their coils et, saves you buying them :)
  • Turbo Ted
17 years 11 months ago #12053 by Turbo Ted
standard cat,i think it is the coils so im going to have a look tomoz and take the coils off,i cant really take the coils out and see if they spark,will have to see wat i can do.cheers for the help though
17 years 11 months ago #12061 by readie si
Replied by readie si on topic bloomin missfire!
Collins wrote: i only replaced the plugs about 2 months ago,and its coil on plug so theres no leads to go wrong.
give the plugs a check never no might have a dud one
but think your on the right track im not familier with renults but i expect its on a coil pack? i had a similar problem on my old escort gti and the focus check the leads for any tears and check the conectors if they seem ok id replace the coil pack and go from there
